I have been trying to build new datasource plugins.But I cannot find the documentation to use grafana’s template components (like <query-editor-row>).
I have read these article but don’t help me: https://pastebin.com/3C334Jj7. (Since I am a new user, I can only post 2 links.)
RIght now, I need autocomplete for Select input. I have read https://github.com/grafana/grafana/issues/410, but I cannot find how to use it. I don’t plan to build the template for query_ctrl and config, because I still believe they already exists.
Are there any references for me to read to build datasource plugin?
Just for sharing, Other than templating, Implemented the datasource’s abstractions are really hard. Like I don’t even know what should I return for datasource(). I can only assume it must return Promise Object…
