I need a help on preparing the JSONata query
I need to group by completeDate and get the average like (“2023-03-12” - “2024-03-08” + “2024-03-11” - “2024-03-05” + “2024-03-11” - “2024-03-02”) / 3, similarly it should perform against all the other entries in the array and the result should be like the “completedDate” and its value.
below is the same data
"completeDate": "2024-03-11 11:00:00",
"returnDate": "2024-03-08 05:00:00",
"item": "123"
"completeDate": "2024-03-11 07:02:00",
"returnDate": "2024-03-05 12:00:00",
"item": "120"
"completeDate": "2024-03-11 07:00:04",
"returnDate": "2024-03-02 23:00:00",
"item": "220"
"completeDate": "2024-03-20 08:00:04",
"returnDate": "2024-03-04 07:00:00",
"item": "221"
"completeDate": "2024-03-20 07:00:10",
"returnDate": "2024-03-11 09:00:00",
"item": "222"
"completeDate": "2024-03-21 10:00:10",
"returnDate": "2024-03-10 09:00:00",
"item": "222"
Output: {
"2023-03-11": 6.3, //assuming
"2024-03-20": 2, , //assuming
"2024-03-21": 1 , //assuming
what have you tried so far? and where are you stuck?
the functions here should be of help
Sorry I forgot to paste the query, below is the query I was trying but it is not working
$reduce(data, function($acc, $v) {
$merge([$acc, {
($substring($v.completeDate, 0, 10)): {
"averageDifference": $avg($map($v, function($item) {
$abs($number($toMillis($replace($item.completeDate, ' ', 'T'))) - $number($toMillis($replace($item.returnDate, ' ', 'T'))))
play with this jsonata
parse-json
| jsonata "($data2 := $ ~> |$|{'clean_date': $substringBefore(completeDate,' ') }|;$data2{clean_date: $count(clean_date)})"
https://try.jsonata.org/u66iRTVgN
Actually the requirement is like I need to groupBy by “completeDate” (excluding time).
let say there are 3 records for 11-03-2024 and 2 records for 20-03-2024 and 1 for 21-03-2024
it should perform a average like for 11-03-24 as (“completeDate” - “returnDate”)
For example:
(“2023-03-11” - “2024-03-08” + “2024-03-11” - “2024-03-05” + “2024-03-11” - “2024-03-02”) / 3 (no of complete dates for that date)
similarly for other complete dates.
and the result would be like
{ date: "2023-03-11", value: somevalue1 },
{ date: "2023-03-20", value: somevalue2 },
{ date: "2023-03-21", value: somevalue3 }
I have prepared a new query something like this not able to understand how to proceed further:
https://try.jsonata.org/TInYqSQCP
try this
${$substringBefore(completeDate,' '): item[]} ~> $each(function($v, $k) {
"date": $k,
"value": $count($v.{"code": $})
Thanks for the updates!
But your output contains the count of number of same completeDate,
But I need to perform a operation as I have mentioned before
For 2023-03-11 it is like:
For “2024-03-20”
(“2023-03-20” - “2024-03-04” + “2024-03-20” - “2024-03-11”) / 2 (no of complete dates for that date)
For “2024-03-21”
(“2023-03-21” - “2024-03-10”) / 1 (no of complete dates for that date)
I hope it is clear now
