My local api service "https://localhost:5001/weatherforecast" was failing when configure in Infinity url
I was trying to access my localhost web api.
CORS is enabled
but when i paste the url i am getting the below error
error getting response from https://localhost:5001/weatherforecast
The same url in the browser is working fine
Browsed in my edge browser, the same url is giving result
This is killing. can you please help me ?
My application is ASP.Net core 3.0 Web API
Hi there… it seems the grafana server is not able to access the url. Can you check curl command in the server itself?
I am the author of the infinity datasource. I would suggest to check in the project repository.
Hi ram,
Thanks for your reply. Sorry for the late response.
I modified with another working url.
“https://www.metaweather.com/api/location/search/?query=london”
if i use that url in the browser, i am able to get the data, but if i put this in the settings, I am not able to get the data
Direct Browser result:
Please help in this.
Note : I am doing this in my windows 2008 & 2016 server (VM). I mean mine is windows environment.
