What Grafana version and what operating system are you using? I am using grafana 8.1.1 and in ubuntu OS
I need to add two panels in same dashboard. one to visualize yesterday’s data in stat plugin and other one to visualize last 30 days statistics in time series plugin panel -
I changed the time frame in top left corner. but I can keep only one time frame. and panels visualization are changed according to that. -
What happened?
See Queries | Grafana Labs and
Time range controls | Grafana Labs
You can set Relative Time and Time Shift independently for each panel.
Antony.
