Grafana V9.0.1 -
- Visualize each standalone prometheus snapshots in Grafana - API (preferred)
- label each snapshot with unique name so that a user can individually select (API preferred)
- ways to delete the prometheus snapshots - API (preferred)
We have prometheus snapshots generated from a remote systems and there is no continuous stream of data. There will be multiple snapshots and trying to visualize each so that they don’t overstep on each other. I believe I have to label each uniquely.
Prometheus snapshot is collected from each remote system as needed using this command:
curl -XPOST :9090/api/v1/admin/tsdb/snapshot
Looking for inputs from the community.
