I have snapshot API setup issue.
Env: Grafana + prometheus + node
“Manually” snapshot will shows correctly with specific panel+node.
e.g. one of the node’s snapshot will looks like this.
Issue:
If I use “Create new snapshot”'s API, page will shows empty and title shows with “ctrl.dashboard.title”, not sure where it comes from.
I thought maybe add id or title into the body will work.
First I got id by “Search panel API” response:
{“id”:3,“title”:“Node Exporter Server Metrics”,“uri”:“db/node-exporter-server-metrics”,“type”:“dash-db”,“tags”:[“prometheus”,“test_tag”],“isStarred”:false},
So I add “id” and “title” into my body and it became like this:
{ "dashboard": { "id":3, "title":"Node Exporter Server Metrics", "editable":false, "hideControls":true, "nav":[ { "enable":false, "type":"timepicker" } ], "rows": [ { } ], "style":"dark", "tags":[], "templating":{ "list":[ ] }, "time":{ }, "timezone":"browser", "title":"Home", "version":5 }, "expires": 3600 }
Response:
“url”:“http://grafana.staged-by-discourse.com/dashboard/snapshot/xxxxxxxxxxxx”
But the result still shows empty on the page with the response url.
Am I wrong? should I need to add anything like node? or tag in the body?
Any advice will be help.
Eric
