Multiple lines in Time Series
I have a table in Mysql with a field that stores the timestamp, another field with the “device_id” and another field with the value “angle”.
In turn, with a variable, I can select the “device_id” from which I want to display data.
But if I select two or more “device_id” it does not show me a line for each one of them but a line continues to appear.
How can I make a line appear showing the “angle” data of each of the “device_id” that I select?
Thanks
Screenshot_213
Screenshot_214
Try to select also device_id in the SELECT section.
When I do this the data doesn’t show
Yes, that’s only one part. Use query inspector to see how is that variable populated with multiple values selected and set correct variable format, so right SQL syntax will be generated in the WHERE section.
Use transformation tab to select time series and then select multi frame
Thanks yosiasz, but doesn’t works
I’m doing it right?
Screenshot_220
You sure are. What data type and timezone is your timedate column?
Is device_id column an integer or a string data type?
Can you provide some sample data in csv format like
timedate,device_id,posicion
2023-05-25 07:22:26,1001,23.5
etc
timedate is datetime
device_id is integer
posicion is float
can I send to you a csv file?
Cool. Just post your csv here. open it in notepad++, copy and paste here like I mentioned ealier
device_id;timedate;posicion
1001;01/01/2023 0:00;10.98
1002;01/01/2023 0:00;10.93
1003;01/01/2023 0:00;10.82
1004;01/01/2023 0:00;10.99
1005;01/01/2023 0:00;11.06
1006;01/01/2023 0:00;11.02
1007;01/01/2023 0:00;11.1
1008;01/01/2023 0:00;11.04
1009;01/01/2023 0:00;9.1
1010;01/01/2023 0:00;11.05
1011;01/01/2023 0:00;11.0
1012;01/01/2023 0:00;11.2
1013;01/01/2023 0:00;9.62
1014;01/01/2023 0:00;11.18
1015;01/01/2023 0:00;11.12
1016;01/01/2023 0:00;11.14
1017;01/01/2023 0:00;9.04
Works for me. You need to make sure the timestamp is UTC
Solved!!!
Screenshot_239
Screenshot_240
