According to documentation you need to add a column named metric:
If you set Format as to Time series, for use in Graph panel for example, then there are some requirements for what your query returns.
Must be a column named time_sec representing a unix epoch in seconds.
Must be a column named value representing the time series value.
Must be a column named metric representing the time series name.
Example:
SELECT
min(UNIX_TIMESTAMP(time_date_time)) as time_sec,
max(value_double) as value,
metric1 as metric
FROM test_data
WHERE $__timeFilter(time_date_time)
GROUP BY metric1, UNIX_TIMESTAMP(time_date_time) DIV 300
ORDER BY time_sec asc
