I wanna add more than one items in a circle. I have to write a conditition.This conditition is ; if device names are same for example CPU and UPTIME information write in a circle.
@bkgann thanks for answer. How can ı create one composite and takes multiple host .I did what you said but ı have more host. Should I create a composite for all host?
The metric argument takes a regex as well as individual metrics names, so you can group them all together as long as the alias has something unique (like the hostname)
its a verry usefull information for me.Can we write a metric for same name.I have big data . I have 4 items for all host but ı dont know what I write for metric.This composite should combine those with the same name.
Using your example, you would alias each metric for “New York”, then name the composite “New York”
If the query was “distance to network york”, aliased as ny_distance,
and "hours to new york, aliased as “ny_hours”
You could make a composite named “New York” and have the metric match “ny_*”
Same for can be applied for Paris.
The actual datasource being used makes a difference on how to query for the metrics, but the above is the general idea.
