I’d like to create a dashboard monitoring EC2 instances including disk usage. Unfortunately CloudWatch can’t read EC2 instance disk usage metric so I will also need to use Prometheus data source to get that values. Is it possible to have two data sources on single dash board? or maybe someone already went through this issue and have different/better solution?
Yes, multiple data sources are supported. Each individual panel on the dashboard has a data source.
yes, multiple data sources within a single panel are supported. More information can be found here:
