Multiple Alerts on a single graph panel?
In the event that it’s relevant, I’m using MySQL, onto the issue:
Having one alert per graph seems counter intuitive with things like the interval variable, it promotes having one graph over two… (i.e. data sent on selected interval vs. data sent per minute AND data sent per hour)
However, I can’t set up alerts to let me know no data has been sent for 5min which could be a potential hiccup, shouldn’t need to check in on it if I’m currently busy, and then a second alert for no data sent for 1h which clearly indicates something is wrong and needs immediate attention…
Is the only remedy for this at the moment just stashing panels into a dashboard with the various alerts you want? or is there some kind of clever workaround I’m not aware of?
I have the same request. Did you work anything out here?
