Is it possible to create more than one alert on the same Graph/Row.
A basic example is to option to split the missing data alert from the alert on the data to allow different intervals
Only one alert rule per graph
Is there a plan for extending this?
I would suggest start with setting a different interval for missing data
10x
what will be the frequency of the rule to trigger an alert , can it be 1000 alerts within a minute or second
