Hello, I defined 3 types of links on my singlestat, but when I switch to View mode, only the first defined link is available. How to make the other 2 links available? Thank you in advance for your help, Tchicken.
in the top left corner there should be an info icon, hover over it
Thank you, I made a mistake in my description, it is in kiosk mode that only the first link is present, maybe this is normal?
