Multiple datalinks on Panels
From fields section of StatPanel or Barchart panel, you can add multiple data links but only 1st shows up on click.
Is it a bug? is there a way to show all the datalinks ?
mine show something like this
I have 2 links: test1 and test2
when the statpanel is clicked, a small box showed up containing 2 links
the config is pretty simple and straightforward
this is what I am expecting . Which version of grafana and stat panel are you using ?
sorry I wasnt clear.
version is 8.0.0
visualization is Stat Panel
this works. our org has customized the plugin hence it was not showing
