Hi all,
I have recently setup a grafana-docker and it seems to work out of the box.
I added a MSSQL data source and tested the connection successfully. However when I try to get data out of the database, the query inspector reports an sql: expected 2 arguments, got 0 error.
My query:
SELECT
$__time(WSDateTime),
temp_batt_room as value
FROM
RFB.dbo.Wv$LiveData$ESS_1_min
WHERE
$__timeFilter(WSDateTime)
ORDER BY
WsDateTime ASC
Result :
However, when I connect with HeidySQL and do a direct query using the executedQueryString from the query inspecor, it seems to work properly
I am not familiar with grafana or MSSQL. I hope that somebody can point me in the right direction, where the error might result from.
Thank you in advance,
Cheers
Dennis
