Downloading the msi file w10 shows this
So my question is, why those msi files not digitally signed?
from where have you downloaded this file?
There is link in first post, but it is https://grafana.com/grafana/download?platform=windows
Reproduce steps:
download is working for me
Yeah, did not write reproduction steps. Now updated and should be more clear.
As mentioned in topic, the msi file is not digitally signed by publisher.
Repeating again my question: why msi file not digitally signed?
again what is problem? you can install and use it. then all is okay.
My question is not answered.
The warning I get when trying to install with windows installer is probably related to this as well:
“grafana-7.3.2.windo…msi was blocked because it could harm your device”
Not exactly great first experience using grafana …
Same issue here. As per company policy we can not run software from untrusted sources on our servers without lots (weeks) of extra work. The MSI simply needs to be signed correctly. It’s not a good idea to distribute professional software in this way.
in that case try the zip file, virus scan it, install it as a service using nssm and you are good to go.
