8.4.6 - What are you trying to achieve?
move from rpm based grafana 8.4.6 to docker based grafana 8.5.27(because we use elasticsearch 6.0) and 11.1.0( try use opensearch) - How are you trying to achieve it?
we use auth.generic_oauth;i copy /etc/grafana and /var/lib/grafana to docker and start the docker - What happened?
i got grafana user already exists and Login failed User sync failed error
I use grafana.abc. net for grafana 8.4.6, and grafana.abc. com for grafana 8.5.27 and grafana.test.abc. net for grafana 11.1.0.
maybe i need to delete all from user table?
Not all, delete only oauth users (and make sure you have backups).
delete from user where name=“user”;
delete from user_auth where user_id=id;
i use these two command to resolve the problem, thank you.
So you “fixed” that only for one particular user. Other oauth users may have the same problem.
yes, after i checked this is work, i will fix all users.
but i got one problem, the role change from admin to viewer
Yeah, it’s a brand new user, so configure role in the same way as you did it for previous user. Only you know how you manage roles.
