Grafana Generic OAuth User Sync error
Grafana v11.x Enterprise deployed on Kubernetes using the kube-prometheus-stack Helm chart. OS: Linux containers (Alpine-based).
Enable OAuth login with Keycloak. Allow users to authenticate via username (not sub) and maintain consistent login behavior even after user recreation in Keycloak.
Using auth.generic_oauth with the following configuration in grafana.ini:
[auth.generic_oauth]
enabled = true
client_id = grafana
name = Keycloak
login_attribute_path = username
name_attribute_path = name
role_attribute_path = contains(resource_access.grafana.roles[*], 'grafanaadmin') && 'GrafanaAdmin' || contains(resource_access.grafana.roles[*], 'admin') && 'Admin' || contains(resource_access.grafana.roles[*], 'editor') && 'Editor' || contains(resource_access.grafana.roles[*], 'viewer') && 'Viewer' || 'NoAccess'
scopes = openid email profile roles
What happened?
OAuth login works fine initially. But if:
  • I delete a user from Keycloak and recreate it (same username),
  • Or I recreate the Identity Provider (IdP) config,
Keycloak assigns a new sub claim, and Grafana throws a User Sync Failed error—even though all other claims (username, email, etc.) are the same.
Grafana should match the user based on the configured login_attribute_path = username, not on sub. Recreated users with the same username should log in successfully.
See the relevant part of grafana.ini above. Here is an example of the user info returned by Keycloak:
NA
And debug logs:
logger=oauth.generic_oauth level=debug msg="Getting user info from API"
logger=oauth.generic_oauth level=debug msg="HTTP GET" url=https://<redacted>/protocol/openid-connect/userinfo status="200 OK"
response_body="{\"sub\":\"...\",\"upn\":\"redact\",\"email_verified\":false,\"name\":\"redact\",\"preferred_username\":\"redact\",\"given_name\":\"redact\",\"family_name\":\"redact\",\"email\":\"redact\",\"username\":\"redact\"}"
logger=oauth.generic_oauth level=debug msg="Received user info response from API" data="Name: match, Displayname: , Login: , Username: match, Email: match, Upn: match, Attributes: map[]"
logger=oauth.generic_oauth level=debug msg="Processing external user info" source=token match
logger=oauth.generic_oauth level=debug msg="Setting user info name from name field"
logger=oauth.generic_oauth level=debug msg="Searching for login among JSON" loginAttributePath=username
logger=oauth.generic_oauth level=debug msg="Set user info email from extracted email"
Yes. UI displays:
Login Failed
User Sync Failed
Grafana logs show debug-level details ending with User Sync Failed.
Yes. Followed:
Question:
Does Grafana internally depend on the sub claim to identify users, even when login_attribute_path = username is explicitly set?
If so, is there a recommended way to avoid this dependency so users recreated in Keycloak don’t get blocked by Grafana?
user sync code
if identity.AuthID != "" && identity.AuthenticatedBy != "" {
    query := &login.GetAuthInfoQuery{AuthId: identity.AuthID, AuthModule: identity.AuthenticatedBy}
    authInfo, errGetAuthInfo := s.authInfoService.GetAuthInfo(ctx, query)
OAuth authentication relies on the provider’s unique user ID (sub claim), not just username and email. When that ID changes, Grafana treats it as a different user, even if other attributes remain the same.
Is my analysis accurate?
Yeah, that can be attack vector, so you may to be less secure:
Thank You.
The Grafana Community appreciates you.
