I wanna use the MongoDB plugin but it appeared error:
How do i fix this problem?
My account cloud is Pay As You Go Pro plan
I upgrade to Pro but it still happen the errors
Vào 14:16, Th 6, 22 thg 12, 2023 Raymond Sowden via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
Yeah you said you were already on the pro tier, that is why i said you should log a ticket, as the pro should give you the license according to the documentation…
As i have researched, i couldn’t find any license and i guess that i must upgrade to upper level for my account to have the license.Am I right?
Vào Th 6, 22 thg 12, 2023 vào lúc 14:39 Raymond Sowden via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
Best thing would be to log a support ticket
I created another grafana account and my cloud is the free account. I have a question about the connection string that:
+If i fill the connection string : mongodb://10.254.59.127:27017, i couldn’t save&test successfully
Vào Th 6, 22 thg 12, 2023 vào lúc 15:21 Tran Bui Hoang <quanhoangsocialwar15@gmail.com> đã viết:
is that ip and port publicly accessible to the outside world?
no, just by the people in the company who connect with the company’s network
Vào Th 6, 22 thg 12, 2023 vào lúc 15:49 Raymond Sowden via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
it needs to be accessible by grafana cloud, or you need to use an agent to send the metrics
Hi , i used this custom plugin : https://github.com/JamesOsgood/mongodb-grafana?tab=readme-ov-file .
This open-source plugin is not supported alerting by Grafana, can i customize it to have the alert in grafana ?
Can you guess how i can customize to have the alert?
Best Regards,
Hoang
Vào Th 6, 22 thg 12, 2023 vào lúc 17:00 Raymond Sowden via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> đã viết:
