What are you trying to achieve?- I need to deploy Grafana on docker for my on prem infra.Then i need to connect Mongo db for dashboard integration but option to connect Mongo db is not available. Once I add the plugins explicitly than after providing Mongo DB details it is showing licens
How are you trying to achieve it?-
by using docker command
docker pull grafana/grafana
docker run -d -p 3000:3000 --name=grafana
-e “GF_DATABASE_TYPE=mongodb”
-e “GF_DATABASE_URL=<mongodb_connection_url>”
-e “GF_DATABASE_NAME=<mongodb_database_name>”
-e “GF_DATABASE_USER=<mongodb_username>”
-e “GF_DATABASE_PASSWORD=<mongodb_password>”
grafana/grafana
What happened? getting error- Enterprise License Error
The Enterprise data source grafana-mongodb-datasource is not available with your current subscription. To activate this data source, please upgrade your plan by visiting Grafana Pricing | Free, Pro, Advanced, Enterprise
Details
license token file not found: /var/lib/grafana/license.jwt -
