Missing permisisons for creating Public Dashboards
I am struggeling with an permission issue I have no explanation for.
I have two Grafana instances on 2 servers (Windows Server 2022) and both have the same version 10.4.2 Enterprise Version no licence. The instances are Independent.
The issue is now that I can create/share a Public Dashboard on one instance but not on the other. Im an EDITOR in both cases. Same config except the hostnames.
public_dashboards is set to TRUE for both.
When I try to create a Public Dashboard link on the second instance I see a message that I am missing the permissions for that:
On the first instance I can create Public Dashboards with no issues.
When I call the permisisons API https:///api/access-control/user/permissions
I see that on the second instance I am missing some permissions in the return like:
dashboards.public:write
We never configured any special permissions for any of those instances.
What can cause this and how can we fix it?
Note:
The instances are independent and they definitely did not receive the same updates all the time but now they are on the same version.
Hi @terr4
I found this issue where they mention that users need Admin permissions for a dashboard in order to create or update public dashboards
