Missing documentation of expandable navbar
Expanding navbar (Beta) was announced with v8.5 but I couldnt see any documentation on the settings and how-to-do except the short information about the feature: What's new in Grafana v8.5 | Grafana documentation
How can I enable this feature? Checked Server Admin/ Settings but couldnt find anything.
welcome to the :grafana: community @duyguaksoy!
The feature is behind the feature toggle newNavigation. You can enable the feature by adding it to the [feature_toggles] section of your grafana.ini file.
For example:
[feature_toggles]
# there are currently two ways to enable feature toggles in the `grafana.ini`.
# you can either pass an array of feature you want to enable to the `enable` field or
# configure each toggle by setting the name of the toggle to true/false. Toggles set to true/false
# will take precedence over toggles in the `enable` list.
# enable = feature1,feature2
enable = newNavigation
You’re right there’s not much documentation out there yet since this is a beta feature. Here is the PR where it was added; there’s some good info here about what changes to expect:
