When we navigate anonymously to a dashboard, I noticed that we can still see the Search and Dashboards->Manage menus in the left navigation bar. I think this is a problem because it means that any anonymous visitor can easily find and view all the dashboard, even if you only want him to see the one dashboard you want him to see.
So I personally think these two menus should be hidden when accessing Grafana anonymously, or provide related options as in Explore menu
#################################### Explore #############################
[explore]
#Enable the Explore section
enabled = false
For examples, add the following two options to grafana.ini:
#################################### Search #############################
[search]
#Enable the Search section
enabled = false
#################################### Dashboards #############################
[dashboards]
#Enable the Dashboards section
enabled = false
