When I try to run Mimir, it complains about port 9095 already being used.
ts=2023-02-21T23:08:51.714171682Z
caller=log.go:65
level=error
msg="error running application"
err="
listen tcp :9095: bind: address already in use
error initialising module: server
github.com/grafana/dskit/modules.(*Manager).initModule
/go/src/github.com/grafana/mimir/vendor/github.com/grafana/dskit/modules/modules.go:122
github.com/grafana/dskit/modules.(*Manager).InitModuleServices
/go/src/github.com/grafana/mimir/vendor/github.com/grafana/dskit/modules/modules.go:92
github.com/grafana/mimir/pkg/mimir.(*Mimir).Run
/go/src/github.com/grafana/mimir/pkg/mimir/mimir.go:752
main.main
/go/src/github.com/grafana/mimir/cmd/mimir/main.go:212
runtime.main
/usr/local/go/src/runtime/proc.go:250
runtime.goexit
/usr/local/go/src/runtime/asm_amd64.s:1594
I am using a very basic config file.
config.yaml
target: all
multitenancy_enabled: false
server:
http_listen_port: 9009
log_level: error
blocks_storage:
backend: filesystem
bucket_store:
sync_dir: /tmp/mimir/tsdb-sync
filesystem:
dir: /tmp/mimir/data/tsdb
tsdb:
When I search the documentation site the only reference to this port is an article about “Grafana Mimir query-tee”, which mentions that port 9095 has to do with a gRPC service.
If port 9095 is a requirement for Mimir to run, it makes sense to me that there would be some prominent documentation about it, probably in the “Get started with Grafana Mimir” document.
If I am already using port 9095 for something else, where do I specify the custom port the configuration?
