Hello, I’m working on Mimir configuration as a single node. And I have 404 error trying to add a data source in Grafana. I suppose there is an error in Miimir configuration. Could someone prompt me?
multitenancy_enabled: false
no_auth_tenant: "rnd"
# We only want to run the query-frontend module.
# target: query-frontend
frontend_worker:
frontend_address: '0.0.0.0:9095'
scheduler_address: ""
dns_lookup_duration: 10s
common:
storage:
backend: s3
s3:
endpoint: s3.eu-central-1.amazonaws.com
region: eu-central-1
secret_access_key: {{ aws_s3_secret_key }} # This is a secret injected via an environment variable
access_key_id: {{ aws_s3_id_key }} # This is a secret injected via an environment variable
blocks_storage:
storage_prefix: blocks
s3:
bucket_name: {{ bucket_name_data }}
tsdb:
dir: /tmp/mimir/tsdb
ship_interval: 1m
block_ranges_period: [ 2h ]
retention_period: 2h
bucket_store:
sync_dir: /tmp/mimir/tsdb-sync
alertmanager_storage:
storage_prefix: alerts
# fallback_config_file: /etc/alertmanager-fallback-config.yaml
# external_url: http://localhost:9009/alertmanager
s3:
bucket_name: {{ bucket_name_alertmanager}}
ruler_storage:
storage_prefix: ruler
# alertmanager_url: http://127.0.0.1:8080/alertmanager
s3:
bucket_name: {{ bucket_name_rules }}
compactor:
data_dir: /tmp/mimir/compactor
store_gateway:
sharding_ring:
replication_factor: 1
server:
http_listen_address: 0.0.0.0
http_listen_port: 9009
# Configure the server to allow messages up to 100MB.
grpc_server_max_recv_msg_size: 104857600
grpc_server_max_send_msg_size: 104857600
grpc_server_max_concurrent_streams: 1000
limits:
# Delete from storage metrics data older than 1 year.
compactor_blocks_retention_period: 1y
distributor:
ring:
instance_addr: 0.0.0.0
kvstore:
store: memberlist
pool:
health_check_ingesters: true
ingester:
ring:
# The address to advertise for this ingester. Will be autodiscovered by
# looking up address on eth0 or en0; can be specified if this fails.
# address: 0.0.0.0
# We want to start immediately and flush on shutdown.
min_ready_duration: 0s
final_sleep: 0s
num_tokens: 512
# Use an in memory ring store, so we don't need to launch a Consul.
kvstore:
store: memberlist
# store: inmemory
