Error 404 Grafana Mimir
Dears,
I’m trying to test Grafana Mimir for potential use in monitoring some servers and services in the future.
My test environment consists of the following:
  1. Instance1: A Vagrant virtual machine with Prometheus and Grafana Mimir installed.
  2. Instance2: A Vagrant virtual machine running node_exporter. Prometheus installed on Machine 1 collects data from it.
  3. Instance3: A Vagrant virtual machine running Telegraf, which sends data to the Prometheus installed on Machine 1.
The problem:
Everything seems to be working okay. When I access Prometheus via http://Instance1:9090, I can query it normally. When I access the others instances (on port 9100 and 9273), I can see the metrics collected for Prometheus. However, when I try to access Grafana Mimir at http://Instance1:9009/prometheus, I receive a “404 page not found” error.
  • My configuration:
On Instance1
Prometheus:
scrape_configs:
  • job_name: “prometheus”
    static_configs:
    • targets: [“localhost:9090”]
  • job_name: ‘node_exporter’
    file_sd_configs:
    • files:
      • node_exporter/nodes.json
        scrape_interval: 5s
  • job_name: ‘telegraf’
    static_configs:
    • targets: [‘intancia3:9273’]
      remote_write:
  • url: My_IP_Here:9009/api/v1/push
Grafana Mimir:
multitenancy_enabled: false
blocks_storage:
backend: filesystem
bucket_store:
sync_dir: /tmp/mimir/tsdb-sync
filesystem:
dir: /tmp/mimir/data/tsdb
tsdb:
compactor:
data_dir: /tmp/mimir/compactor
sharding_ring:
kvstore:
store: memberlist
distributor:
ring:
instance_addr: 127.0.0.1
kvstore:
store: memberlist
ingester:
ring:
kvstore:
store: memberlist
replication_factor: 1
ruler_storage:
backend: filesystem
filesystem:
dir: /tmp/mimir/rules
server:
http_listen_port: 9009
log_level: error
store_gateway:
sharding_ring:
Of course, I plan to apply a more suitable configuration in production, but for initial tests, all I wanted was to see Grafana Mimir working so that I could then expand the testing.
What might be wrong in this case? Could someone help me ?
Thanks.
I have kind of the same problem, but with mimir-distributed (installed with helm chart).
Any solution out there?
Hi
did you tried to set the header ‘X-Scope-OrgID’ on datasource configuration ?
In conf file:
On UI:
Yes
I did it
I think it solved the problem
Thanks for help
Hello
I am running mimir on it on single server, what would be my X-Scope-OrgID?
