Mimir data ingested but not exposed
I’m running Grafana Mimir 2.11.0 on Linux, as a Docker container.
I’m experimenting with Mimir and try to ingest data from Prometheus and show it in a Grafana dashboard.
I’m running Mimir through the following Docker compose file:
version: "3.4"
services:
  mimir:
	image: grafana/mimir:latest
	command: ["-config.file=/etc/mimir.yaml"]
	container_name: mimir
	hostname: mimir
	volumes:
	  - /container/mimir/config/mimir.yaml:/etc/mimir.yaml
	  - /container/mimir/config/alertmanager-fallback-config.yaml:/etc/alertmanager-fallback-config.yaml
	ports:
	  - "9009:9009"
	  - "8080:8080"
	restart: always
The file mimir.yaml contains this:
# Run Mimir in single process mode, with all components running in 1 process.
target: all,alertmanager,overrides-exporter
# Configure Mimir to use Minio as object storage backend.
common:
  storage:
    backend: s3
    s3:
      endpoint: minio.mydomain
      access_key_id: {{ mimir_s3_access_key_id }}
      secret_access_key: {{ mimir_s3_secret_access_key }}
      bucket_name: mimir
# Blocks storage requires a prefix when using a common object storage bucket.
blocks_storage:
  storage_prefix: blocks
  tsdb:
    dir: /data/ingester
# Use memberlist, a gossip-based protocol, to enable the 3 Mimir replicas to communicate
memberlist:
  join_members: [mimir]
ingester:
  ring:
    replication_factor: 1
ruler:
  rule_path: /data/ruler
  alertmanager_url: http://127.0.0.1:8080/alertmanager
  ring:
    # Quickly detect unhealthy rulers to speed up the tutorial.
    heartbeat_period: 2s
    heartbeat_timeout: 10s
alertmanager:
  data_dir: /data/alertmanager
  fallback_config_file: /etc/alertmanager-fallback-config.yaml
  external_url: http://localhost:9009/alertmanager
server:
  log_level: warn
And alertmanager-fallback-config.yaml contains the standard sample content:
route:
  group_wait: 0s
  receiver: empty-receiver
receivers:
  # In this example we're not going to send any notification out of Alertmanager.
  - name: "empty-receiver"
Prometheus is configured to ingest into Mimir:
remote_write:
  - url: http://host.mydomain:8080/api/v1/push
    headers:
      X-Scope-OrgID: test-tenant
What happened?
Ingestion from Prometheus apparently works, as I see data in Minio (it’s running for 3 days now) and the page ingester/tsdb/test-tenant shows Number of series: 10678. However, when I fetch the labels through curl -s --header "X-Scope-OrgID: test" http://host.mydomain:8080/prometheus/api/v1/label/__name__/values, I get only this:
{"status":"success","data":[]}
When I explore the data source in Grafana, it shows “(No metrics found)”.
See the metrics in Grafana and be able to build dashboards.
Did you receive any errors in the Grafana UI or in related logs?
None at all.
Basically Get started with Grafana Mimir | Grafana Mimir documentation, but Grafana and Prometheus are spun up separately instead of through the compose file.
I’m crashing into so many problems with Grafana/Mimir/Alloy. Every question I find like this just sits there unanswered, and if they are answered it is because of a simple configuration problem. I fear that these applications were all developed with happy paths in mind.
I ran into something similar. I was publishing my metrics to Mimir through the opentelemetry-tollector’s Prometheus remote write exporter, so this should be very similar to the prometheus configuration above. I was doing the same thing here, setting the tenant header:
prometheusremotewrite/controlplane-prometheus:
        endpoint: ${env:PROMETHEUS_EXPORTER_URL}
        headers:
          "X-Scope-OrgID": common
I had to make sure I was setting the same header when setting up my Grafana datasource:
