Hi Team,
Planning to use the K6 Prometheus experimental features, and I need to migrate my existing k6 data from InfluxDB 1.8 to Prometheus. Can someone guide me?
Hi Team,
Hi @Gerard
Migrating the data might be a complex process (not sure if doable). We would recommend you keep the InfluxDB around if you need the older data.
Cheers!
Thanks @eyeveebe
Thinking this way to acheive it, but need to try and see and it helps.
Guide me, if you have any other thoughts.
