Grafana 9.3 -
Migrating to 11.2 -
What happened?
One of the panels i dashboards has issues with “Extract Fields” transformation applied after “Series to Rows”. Using Google Cloud Monitoring datasource -
In the source field it says “Metric (Not Found”. When I debug the “Series to Rows”, that field label is there -
I don’t think so
The expected result after applying the Series to Rows transformation in Metrics column
{metric.label.operation_id=“UNDEFINED”, metric.label.proxy_base_path=“/maas-external”, metri……}
I get string
/process-engine/public/rt/infa_gcc_api_customer_v1_tccprod_CreateUpdateContact UNDEFINED 200 -
No Data -
No, I read the documentation in Grafana Docs about the Transformations
