11.1.0 -
I am trying to create a Stat view dashboard by using a time series data which comes every 4 hours -
I have setup a prometheus Job which will query a http URL and send the metrics every 4 hours . I have few of custom labels in my metrics ( one of them is REPORT) -
What happened?
When i try to apply any kind of transformation on my metrics, I am losing REPORT field label -
I dont want to lose any field labels when i apply transformation -
No error -
No
