Grafana novice here, feeling my way through things.
I’m trying to subtract the result of one query from another (each a single stat), using the MetaQuery plugin. As per the screenshots below, each query (A and B) returns a result (“_value”) but when I try to subtract B from A (A[‘_value’] - B[‘_value’]) I don’t get a result. I assume my syntax in the MetaQuery expression is incorrect, but I’m not sure how. I would appreciate any help!
What Grafana version and what operating system are you using? 9.3.2 (Docker), Windows !!
What are you trying to achieve? subtract one query result (single stat) from another
How are you trying to achieve it? MetaQueries plugin
What happened? Returns blank result
What did you expect to happen? a value for A minus B
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No errors
