Grafana v11.3, Windows 11 -
I want to display a merged header (see attached image) on my table and at the same time, display colored background cell option. How do I do this with Volkovlabs’ table plugin?
Currently, I am using Grafana’s stock table to achieve the colored background. Unfortunately, I cannot do the merged header using it. So, I’m thinking of using a plugin that could do both. -
What happened?
None -
N/A
Continue in the other thread already started
