Grafana v11.3, Windows 11 -
To visually display the attached image by merging the top row across the relevant columns while keeping individual data columns separate. It helps organize and clarify relationships between data columns.
I don’t know yet if it is possible. -
What happened?
N/A -
To have a merged header similar to attached image. -
N/A -
N/A -
N/A
Yes, by using not the stock table plugin but by using business text plugin and some html
Helloo, Sir/Ma’am. I used the grafana stock table since I have to use the cell option > colored background. Is this possible with business table plugin instead?
@yosiasz May I know how to do both the merged header and colored background cell option using the business table plugin? I can’t find any documentation regarding those two… Appreciate the help! Thank youu
Here is the docu for it and will require some html knowledge
Read it, and Try it out and when you are stuck will be more than happy to guide you
