Using business text plugin, please share how to build a table using for each loop and also merging the table column headers
Hello @yosiasz,
To build a table using the Business Text plugin with a for each loop and merge table column headers, you can leverage the Handlebars templating engine that the plugin supports. Here's a basic example to get you started:
Step-by-Step Guide
Install the Business Text Plugin: Ensure you have the Business Text plugin installed in your Grafana instance. You can do this via the Grafana Plugins catalog or using the Grafana CLI.
Prepare Your Data: Make sure your data source is returning the data you want to display in the table. The data should be structured in a way that you can iterate over it.
Create a Template: Use the Handlebars syntax to create a table. Here's a simple example:
```html
| Merged Header | Other Header | |
| Sub Header 1 | Sub Header 2 | Other Header |
| {{this.subField1}} | {{this.subField2}} | {{this.otherField}} |
{{#each yourData}}: This is where you loop over your data. ReplaceyourDatawith the actual data object you are working with.-
<th colspan="2">Merged Header</th>: This is how you merge table headers. Adjust thecolspanattribute based on how many columns you want to merge. -
Customize and Style: You can add CSS styles directly in the template or use external stylesheets to customize the appearance of your table.
Test and Iterate: Preview your panel to ensure the table renders correctly. Adjust the Handlebars template and data as needed.
Additional Tips
- Data Preparation: Ensure your data is structured in a way that makes it easy to iterate over with Handlebars. You might need to preprocess your data in Grafana or your data source.
- Debugging: Use the console or logging within your Handlebars template to debug and verify data values.
This should give you a good starting point to create dynamic tables with merged headers using the Business Text plugin. If you have specific data or additional requirements, feel free to share more details!
xoxo Grot
grot is still learning and improving, please let me know how I did by reacting below.
Hi @yosiasz,
It looks like you're interested in using the Business Text plugin to create a table with merged column headers using a for each loop. The Handlebars templating engine is indeed a great tool for this task. If you have any specific questions or run into issues while implementing the example provided, feel free to ask for more detailed guidance.
If you need further assistance with specific data structures or additional customization, please provide more details about your data or the specific outcome you're aiming for. This will help in tailoring the solution to better fit your needs.
Looking forward to helping you further!
xoxo Grot
