Merge two columns into a third
Hello, I am on Grafana 9.2.3
Considering two columns (A and B) from a Table with missing values. Is it possible to create an other column without “Missing” like C ?
grafana
Thank you for reading
Regards,
Welcome
What is your datasource? Mysql? Does the data literally say Missing?
Datasource : Elastic
No, the datasource don’t say “missing”, I just add in the “missing” field on "Transorm
The data will be “text” but that can be “numeric” too.
Regards.
Something like this
Thank you,
That is not bad ! For that I have to add a space instead of “missing” on missing field.
But I have a little probleme.
For exemple, if A have value “ping” and B have value “pong”, C will have value “pingpong” and, it’s logical !
Because some time, I have value on A and B, but not always
When I have value on A and B, I just need to have the value from A on C, and not A+B.
A + B is good if A or B are empty. But is A and B have value, it’s a little problem.
Thank you for your time.
Regards.
You earlier said there is no literal value of Missing? Are you say instead of blank there is a dash?
In that case it is a rltext field. “2” is not numeric it is text field
This requirement is opposite of what you posted in the picture
