What Grafana version and what operating system are you using? version: 11.1.0 and Windows
I’m trying to merge rows based on the column values.
namespace/resource | image_repo/imagetag | Severity | Column 4 |
alpha/redis1 | bitnami/1 | Critical | 10 |
alpha/redis1 | bitnami/1 | High | 5 |
alpha/redis2 | bitnami/1 | Critical | 10 |
alpha/redis2 | bitnami/1 | High | 5 |
alpha/redis3 | bitnami/1 | Critical | 10 |
alpha/redis3 | bitnami/1 | High | 5 |
If you see the images, namespace (alpha) has 3 different resources (redis1, redis2, redis3) with same image_repo(bitnami) and same image_tag(1) with two different severities (critical and high).
So, I need to merge row 1,3,5 and row 2,4,6, because they have same namespace, same image_repo/image_tag and same severities, which should look like this after merging/combining:
Data source: Prometheus
PromQL I’m using:
sum by (namespace, resource_name,combined_label_1,severity)(
label_join(
label_join(
trivy_image_vulnerabilities,
“combined_label”,
“namespace”,
“resource_name”
“combined_label_1”,
“image_repository”,
“image_tag”
