Maximum per day over non_negative_derivative
As the title, I have a metric where I get the bytes volume of a router’s interface, that I convert to rate with non_negative_derivative.
I need to get the maximum and minimum rate per day but I can’t figure out how to do it. I tried with nested queries, like this:
SELECT max
  FROM (
       SELECT non_negative_derivative(mean("IF-MIB::ifHCInOctets.116.TASA"), 1s)
         FROM "ne8k.hq.sslocal"
        GROUP BY time(1h) fill(previous)
      ) WHERE $timeFilter
GROUP BY time(24h) fill(0);
But I’m getting an error:
InfluxDB Error: GROUP BY requires at least one aggregate function
Removing the last group_by statement clears the error, but I got no results.
How can I solve this issue?
Many thanks in advance and sorry for poor english, Diego
Thank you!! That did the trick. It works perfectly!
