Filter by time but not date or drop first record...?
Hi folks,
I am very new to all this, I had some SQL experience years ago so the concepts feel familiar but assuming I know nothing, or worse have made some faulty assumptions, is where my head is right now so please bear that in mind when I ask inevitably stupid stuff !
Specifics… Well as close as I can get right now.
I have an Influx database, and Grafana, running on a Home Assistant RPI
One of my sensors, so data, is kWh, and is attached to multiple entities.
I am not going to pretend that I know the table/s structure but obviously it must contain a timestamp and the data at least.
I built this, using the GUI :-
SELECT max(“value”) FROM “kWh” WHERE (“entity_id”::tag = ‘caravan_and_workshop_4_1d’) AND $timeFilter ORDER BY time DESC
and then modified it to :-
SELECT “value” AS “Caravan” FROM “kWh” WHERE (“entity_id”::tag = ‘caravan_and_workshop_4_1d’) AND $timeFilter GROUP BY interval_day
with an aggregate MAX in the value options of the card.
The latter, sort of works but there is a data anomaly causing a problem.
The data is collected every minute, and being cumulative, is an ascending value.
For any $TimeFilter period, or any other method of getting a dataset, I need to group by a date, not time, and return a Max value.
The issue is that the first record in most ‘days’ is actually the last value of the previous day, typically captured 15-20 seconds after midnight so at 00:10… I have 10 records but only 9 of them are actually the correct day, from a value perspective, with all having a timestamp, and associated date for the group, that is in range.
Timeshift seemed an obvious solution but I cant get it to work, mor likely do not know what I am doing, so I started looking at how to do something like this:-
WHERE (“entity_id”::tag = ‘caravan_and_workshop_4_1d’) AND $timeFilter AND time > 00:01:00.000
AND time > 00:01:00.000 just gives me an error and I have tried multiple ways of specifying the time to do this but none so far have helped.
A couple of attempts, looked promising, not that I can remember which, but anything that wasn’t simply wrong syntax complained about not being able to compare time to a literal.
Obviously I am missing something and data anomalies like this are common so this must be possible and should be easy…
Please help if you can… I am feeling more than a little silly here, filter by time or drop the first record of a row set is hardly rocket science.
Cheers,
Al
May be aggregation using LAST() would help you.
See this topic:
Thanks that is helpful BUT my lack of understanding still leaves me with questions.
I had tried Last, well Last * at least, and it sort of works.
I have, at least I think I have, a couple of concerns…
  1. I do not know what the native order is so do not know if first/last would be consistent.
  2. If $timeFilter spans multiple days I would ideally like multiple records, of max(value) grouped by day. Once I add Max in the query I am including the bad value… Hang on… You made me re-evaluate…
That gave me an idea whilst typing and it appears I have bigger problems in that
isn’t working.
Tried datepart() but aparantly that isn’t right either.
The strategy you suggest will likely work if I can get the GROUP right…
GROUP BY time(1d) looks promising, playing…
OK…
so this:-
SELECT max(“value”) FROM “kWh” WHERE (“entity_id”::tag = ‘caravan_and_workshop_4_1d’) AND $timeFilter GROUP BY time(1d) ORDER BY time(1d) DESC
seems to work with QI returning the records I expect,all be it still with one extra day:- [From QI]
SELECT max(“value”) FROM “kWh” WHERE (“entity_id”::tag = ‘caravan_and_workshop_4_1d’) AND time >= 1717023600000ms and time <= 1717455599000ms GROUP BY time(1d) ORDER BY time DESC
2024-06-03 01:00:00 989 Wh
2024-06-02 01:00:00 1.59 kWh
2024-06-01 01:00:00 1.16 kWh
2024-05-31 01:00:00
Playing with timeshift and relative isn’t helping, I need to drop the single record from 31st. Using Last, or first for that matter, as suggested earlier gets me either the first or last day, which is better than I was getting before, but isn’t going to help with data that needs to be represented for multiple days.
In an Ideal world the data, which is feeding a simple vertical, bar right now would be filling a histogram, or perhaps SD, that gives an impression of the value spread over the period whilst still displaying the max and min values.
I guess t bars, Min/Max/Avg would do but even at that the stray day will mess things up.
(Just to clarify I mean Min / Avg / Max of the grouped days not an individual day)
Can I modify/transform the contents of $timeFilter? just adding1 minute to the first term would do, yes I know I would still not be seeing the last record for the latest day and running the query at 00:00:nn would miss a day but I can live with that, If I have to, the data is what it is.
