Hi. I’m trying to use a timestamp(ms since 1970) in the query below
SELECT “usage_idle” FROM cpu where time = 1504909620000
Is it possible?
Thank you
Is it possible?
Thank you
Yes, is the short answer but with time = 1504909620000 you will at most get one data point. You could change it to time >= 1504909620000 to get all metrics with a timestamp greater than that date.
Is this a special query or why not just use the inbuilt time range functions in Grafana?
Here is a similar query in raw query mode in Grafana. The $timeFilter variable is the time range that is chosen in the Grafana datepicker:
SELECT mean("value") FROM "cpu" WHERE $timeFilter GROUP BY time($__interval) fill(null) ORDER BY time DESC
This gets translated to the real query:
SELECT mean("value") FROM "cpu" WHERE time >= now() - 30m GROUP BY time(10s) fill(null) ORDER BY time DESC
