today I’ve updated my Grafana Loki container with latest image and it does not load config because of this error:
failed parsing config: /etc/loki/local-config.yaml: yaml: unmarshal errors:
line 49: field max_look_back_period not found in type chunk.StoreConfig
Config is this:
chunk_store_config:
max_look_back_period: 336h
I gave a look at the source code and they’ve removed that parameter from chunk_store config, but official docs still mentions that parameter. I’ve set it equal to table_manager retention_period, is it something that shouldn’t be used or has it been replaced with another parameter? Actual chunk_store allows for these parameters looking at source code:
// StoreConfig specifies config for a ChunkStore
type StoreConfig struct {
ChunkCacheConfig cache.Config `yaml:"chunk_cache_config"`
WriteDedupeCacheConfig cache.Config `yaml:"write_dedupe_cache_config"`
CacheLookupsOlderThan model.Duration `yaml:"cache_lookups_older_than"`
// Not visible in yaml because the setting shouldn't be common between ingesters and queriers.
// This exists in case we don't want to cache all the chunks but still want to take advantage of
// ingester chunk write deduplication. But for the queriers we need the full value. So when this option
// is set, use different caches for ingesters and queriers.
chunkCacheStubs bool // don't write the full chunk to cache, just a stub entry
// When DisableIndexDeduplication is true and chunk is already there in cache, only index would be written to the store and not chunk.
DisableIndexDeduplication bool `yaml:"-"`
