I have a loki configured as follows:
"auth_enabled": false,
"chunk_store_config": {
"max_look_back_period": "744h"
"compactor": {
"compactor_ring": {
"kvstore": {
"store": "inmemory"
"shared_store": "filesystem",
"working_directory": "${baseDir}"
"ingester": {
"chunk_idle_period": "1h",
"chunk_retain_period": "30s",
"chunk_target_size": 999999,
"lifecycler": {
"address": "127.0.0.1",
"ring": {
"kvstore": {
"store": "inmemory"
"replication_factor": 1
"max_chunk_age": "1h",
"max_transfer_retries": 0
"limits_config": {
"reject_old_samples": true,
"reject_old_samples_max_age": "168h",
"retention_period": "744h"
"schema_config": {
"configs": [
"from": "2022-06-06",
"index": {
"period": "24h",
"prefix": "index_"
"object_store": "filesystem",
"schema": "v11",
"store": "boltdb-shipper"
"server": {
"http_listen_port": 3030,
"log_level": "warn"
"storage_config": {
"boltdb_shipper": {
"active_index_directory": "${baseDir}/boltdb-shipper-active",
"cache_location": "${baseDir}/boltdb-shipper-cache",
"cache_ttl": "24h",
"filesystem": {
"directory": "${baseDir}/chunks"
"table_manager": {
"retention_deletes_enabled": true,
"ruler": {
"enable_api": true,
"enable_alertmanager_v2": true,
"ring": {
"kvstore": {
"store": "inmemory"
"rule_path": "/var/lib/loki/rules-temp",
"alertmanager_url": "http://127.0.0.1:3041",
"storage": {
"type": "local",
"local": {
"directory": "${baseDir}/rules"
However, I still have chunks from September.
I have tried:
curl -g -XPOST 'http://localhost:3030/v1/delete?end=1704063600'
but I have got a 404.
Anything wrong in my configuration?
Thanks in advance for your help,
Regards.
