Delete old chunks from loki
Hello!
I configured deletion of old chunks via Table Manager. But the data is not deleted.
Now disk is full. Should I use a Compactor or is there something wrong in my config ?
auth_enabled: false
server:
  http_listen_port: 3100
ingester:
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
    final_sleep: 0s
  chunk_idle_period: 5m
  chunk_retain_period: 30s
  max_transfer_retries: 0
schema_config:
  configs:
      store: boltdb
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 168h
storage_config:
  boltdb:
    directory: /data/loki/index
  filesystem:
    directory: /data/loki/chunks
limits_config:
  enforce_metric_name: false
  reject_old_samples: true
chunk_store_config:
  max_look_back_period: 0s
table_manager:
  retention_deletes_enabled: true
  retention_period: 180d
Yes, I’d say use compactor instead, and disable table manager altogether.
Thank you for your answer!
Will this be a working config if I want chunks to be deleted after 180 days?
auth_enabled: false
server:
ingester:
  lifecycler:
    address: 127.0.0.1
    ring:
      kvstore:
        store: inmemory
    final_sleep: 0s
schema_config:
  configs:
      store: boltdb
      schema: v11
      index:
        prefix: index_
        period: 168h
storage_config:
  boltdb:
  filesystem:
compactor:
  working_directory: /data/loki/retention
  shared_store: filesystem
  retention_enabled: true
  retention_delete_delay: 2h
  retention_delete_worker_count: 150
  deletion_mode: filter-and-delete
  delete_request_cancel_period: 5m
limits_config:
chunk_store_config:
  max_look_back_period: 180d
#table_manager:
#  retention_deletes_enabled: true
#  retention_period: 180d
I think that looks good. I’d say test it in a dev environment real quick and make sure at least the compactor doesn’t complain about configuration.
