Filesystem retention not working
I want to purge all chunks older than 31 days in loki so I set this config
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_
        period: 24h
storage_config:
  boltdb_shipper:
    active_index_directory: "/var/lib/loki/boltdb-shipper-active"
    cache_location: "/var/lib/loki/boltdb-shipper-cache"
    cache_ttl: 24h
    shared_store: filesystem
  filesystem:
    directory: /var/lib/loki/chunks
compactor:
  working_directory: "/var/lib/loki/boltdb-shipper-compactor"
chunk_store_config:
  max_look_back_period: 0s
table_manager:
  retention_deletes_enabled: true
  retention_period: 31d
version: 2.4.1
but this is not working.
Did I forget something to set ?
Did you wait for deletion, there is a relevant discussion in Github i suggest you have a look at it first :
Hope it helps.
Good Luck
actually starting in version 2.4.0 it’s necessary to update the configuration to purge old data, by
  • defining the retention period in section limits_config
  • activate the retention in section compactor
which gives
 compactor:
  retention_enabled: true
limits_config:
  retention_period: [30d]
this is explained in the upgrade document I did not know about
Hello,The chunks are deleted or not? I’m having a problem with full disk space
Same here, getting disk space issue with loki 2.4.1. Did you got the solution
compactor did work , I cant query the logs after retention period
but chunk files did exist in my disk
