server:
grpc_listen_port: 9095
http_listen_port: 3100
auth_enabled: false
chunk_store_config:
max_look_back_period: 0s
ingester:
chunk_block_size: 262144
chunk_idle_period: 3m
chunk_retain_period: 1m
lifecycler:
ring:
replication_factor: 1
max_transfer_retries: 0
wal:
dir: /data/loki/wal
compactor:
working_directory: /data/retention
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
delete_request_store: alibabacloud
limits_config:
retention_period: 168h
enforce_metric_name: false
max_entries_limit_per_query: 5000
reject_old_samples: true
schema_config:
configs:
store: tsdb
object_store: alibabacloud
schema: v13
index:
prefix: index_
period: 24h
storage_config:
tsdb_shipper:
active_index_directory: loki/index
cache_location: loki/index_cache
alibabacloud:
bucket: ***
endpoint: ***
access_key_id: ***
secret_access_key: ***
What is the log said?
can you help me.
The logs are pretty clear. You have configurations that are not where they should be. For example, query_store_max_look_back_period should be under engine of a particular component such as ingester or querier. I’d say cross reference the logs and the documentation (Grafana Loki configuration parameters | Grafana Loki documentation) and correct them.
