Grafana loki http 500 on range queries
Dear community, could anyone please guide me, what is wrong with my config:
      auth_enabled: false
      server:
        http_listen_port: {{ .Values.loki.containerPorts.http }}
        grpc_listen_port: {{ .Values.loki.containerPorts.grpc }}
        http_server_read_timeout: "1h"
        http_server_write_timeout: "5m"
        http_server_idle_timeout: "5m"
        grpc_server_max_recv_msg_size: 41943040
        grpc_server_max_send_msg_size: 41943040
        log_level: debug
      common:
        compactor_address: http://{{ include "grafana-loki.compactor.fullname" . }}:{{ .Values.compactor.service.ports.http }}
      distributor:
        ring:
          kvstore:
            store: memberlist
      memberlist:
        join_members:
          - {{ include "grafana-loki.gossip-ring.fullname" . }}
      ingester:
        lifecycler:
          ring:
            kvstore:
              store: memberlist
            replication_factor: 1
        chunk_idle_period: 30m
        chunk_block_size: 262144
        chunk_encoding: snappy
        chunk_retain_period: 1m
        wal:
          dir: {{ .Values.loki.dataDir }}/wal
      limits_config:
        retention_period: 36h
        reject_old_samples: true
        reject_old_samples_max_age: 68h
        max_cache_freshness_per_query: 10m
        split_queries_by_interval: 30m
        max_query_parallelism: 8
        allow_structured_metadata: true
      schema_config:
        configs:
          store: boltdb-shipper
          object_store: filesystem
          schema: v11
          index:
            prefix: index_
            period: 24h
          store: tsdb
          schema: v12
          index:
            period: 24h
            prefix: index_
          store: tsdb
          schema: v13
          index:
            prefix: index_
            period: 24h
      storage_config:
        boltdb_shipper:
          active_index_directory: {{ .Values.loki.dataDir }}/loki/index
          cache_location: {{ .Values.loki.dataDir }}/loki/cache
          cache_ttl: 168h
          {{- if .Values.indexGateway.enabled }}
          index_gateway_client:
            server_address: {{ (printf "dns:///%s:9095" (include "grafana-loki.index-gateway.fullname" .)) }}
          {{- end }}
        filesystem:
          directory: {{ .Values.loki.dataDir }}/chunks
        index_queries_cache_config:
          {{- if .Values.memcachedindexqueries.enabled }}
          memcached:
            batch_size: 100
            parallelism: 100
          memcached_client:
            consistent_hash: true
            addresses: dns+{{ include "grafana-loki.memcached-index-queries.host" . }}
            service: http
          {{- end }}
        tsdb_shipper:
          active_index_directory: {{ .Values.loki.dataDir }}/loki/tsdb-index
          cache_location: {{ .Values.loki.dataDir }}/loki/tsdb-cache
          {{- end }}
      query_scheduler:
        max_outstanding_requests_per_tenant: 2048
      querier:
        max_concurrent: 16
      chunk_store_config:
        {{- if .Values.memcachedchunks.enabled }}
        chunk_cache_config:
          memcached:
            batch_size: 100
            parallelism: 100
          memcached_client:
            addresses: dns+{{ include "grafana-loki.memcached-chunks.host" . }}
        {{- end }}
        {{- if .Values.memcachedindexwrites.enabled }}
        write_dedupe_cache_config:
          memcached:
            batch_size: 100
            parallelism: 100
          memcached_client:
            addresses: dns+{{ include "grafana-loki.memcached-index-writes.host" . }}
        {{- end }}
      table_manager:
        retention_deletes_enabled: false
        retention_period: 0s
      query_range:
        parallelise_shardable_queries: false
        align_queries_with_step: true
        max_retries: 5
        cache_results: true
        results_cache:
          cache:
            {{- if .Values.memcachedfrontend.enabled }}
            memcached_client:
              addresses: dns+{{ include "grafana-loki.memcached-frontend.host" . }}
              max_idle_conns: 16
              timeout: 500ms
              update_interval: 1m
            {{- else }}
            embedded-cache:
              enabled: true
              max_size_items: 1024
              validity: 24h
            {{- end }}
      {{- if not .Values.queryScheduler.enabled }}
      frontend_worker:
        frontend_address: {{ include "grafana-loki.query-frontend.fullname" . }}:{{ .Values.queryFrontend.service.ports.grpc }}
      {{- end }}
      frontend:
        log_queries_longer_than: 5s
        compress_responses: true
        tail_proxy_url: http://{{ include "grafana-loki.querier.fullname" . }}:{{ .Values.querier.service.ports.http }}
      compactor:
        working_directory: {{ .Values.loki.dataDir }}/loki/retention
        compaction_interval: 10m
        retention_enabled: true
        retention_delete_delay: 2h
        retention_delete_worker_count: 150
        delete_request_store: filesystem
      ruler:
        storage:
          type: local
          local:
            directory: {{ .Values.loki.dataDir }}/conf/rules
        ring:
          kvstore:
            store: memberlist
        rule_path: /tmp/loki/scratch
        alertmanager_url: https://alertmanager.xx
        external_url: https://alertmanager.xx
All pods starting well, and I can perform queries in grafana.
But on some queries, like:
sum by(path) (count_over_time({app="$app", pod=~"$pod", msg=~"Request validation error.*"} [$__auto]))
I’m getting an error:
failed to load chunk 'fake/89ac1eeb4dfd38f0/MThmZWQ0YTRiMTk6MThmZWQ3NGI1MGQ6YTFkMDI3NTc=': open /bitnami/grafana-loki/chunks/fake/89ac1eeb4dfd38f0/MThmZWQ0YTRiMTk6MThmZWQ3NGI1MGQ6YTFkMDI3NTc=: no such file or directory
it happens with all range functions like rate, count_over_time, etc.
I do see errors in logs in grafana-loki-gateway:
api-firewall-grafana-loki-query-frontend-b94b698b5-62hz2 level=error ts=2024-06-06T13:59:12.782522911Z caller=retry.go:95 org_id=fake traceID=4d875331af9f1043 msg="error processing request" try=1 query="sum by (path)(count_over_time({app=\"api-firewall\", pod=~\".*\", msg=~\"Shadow API: undefined parameters found\"}[1h]))" query_hash=865803805 start=2024-06-06T13:59:11.84Z end=2024-06-06T13:59:11.84Z start_delta=942.514911ms end_delta=942.515601ms length=0s retry_in=1.511103519s err="rpc error: code = Code(500) desc = failed to load chunk 'fake/c2838354379276cd/MThmZWQ4NjU0OWY6MThmZWRhYjY3N2Y6YWIxMWYzNGM=': open //grafana-loki/chunks/fake/c2838354379276cd/MThmZWQ4NjU0OWY6MThmZWRhYjY3N2Y6YWIxMWYzNGM=: no such file or directory"
api-firewall-grafana-loki-query-frontend-b94b698b5-62hz2 level=error ts=2024-06-06T13:59:15.027658792Z caller=retry.go:95 org_id=fake traceID=4d875331af9f1043 msg="error processing request" try=2 query="sum by (path)(count_over_time({app=\"api-firewall\", pod=~\".*\", msg=~\"Shadow API: undefined parameters found\"}[1h] offset 1h0m0s))" query_hash=2834255071 start=2024-06-06T13:59:11.84Z end=2024-06-06T13:59:11.84Z start_delta=3.187652568s end_delta=3.187653082s length=0s retry_in=4.365943429s err="rpc error: code = Code(500) desc = failed to load chunk 'fake/d4f620a5d3a8b02d/MThmZWQ0N2JlMmU6MThmZWQ3MDc2NWY6NzJhYjUzNDU=': open //grafana-loki/chunks/fake/d4f620a5d3a8b02d/MThmZWQ0N2JlMmU6MThmZWQ3MDc2NWY6NzJhYjUzNDU=: no such file or directory"
api-firewall-grafana-loki-query-frontend-b94b698b5-62hz2 level=error ts=2024-06-06T13:59:15.861341747Z caller=retry.go:95 org_id=fake traceID=4d875331af9f1043 msg="error processing request" try=2 query="sum by (path)(count_over_time({app=\"api-firewall\", pod=~\".*\", msg=~\"Shadow API: undefined parameters found\"}[1h]))" query_hash=865803805 start=2024-06-06T13:59:11.84Z end=2024-06-06T13:59:11.84Z start_delta=4.02133455s end_delta=4.021335003s length=0s retry_in=4.125772618s err="rpc error: code = Code(500) desc = failed to load chunk 'fake/f31df9b987ce323b/MThmZWQ5ZWM0NTI6MThmZWRhM2NkZjY6N2UwYzYxNDg=': open //grafana-loki/chunks/fake/f31df9b987ce323b/MThmZWQ5ZWM0NTI6MThmZWRhM2NkZjY6N2UwYzYxNDg=: no such file or directory"
api-firewall-grafana-loki-query-frontend-b94b698b5-62hz2 level=error ts=2024-06-06T13:59:15.974877155Z caller=retry.go:95 org_id=fake traceID=4d875331af9f1043 msg="error processing request" try=2 query="sum by (path)(count_over_time({app=\"api-firewall\", pod=~\".*\", msg=~\"Shadow API: undefined parameters found\"}[1h] offset 2h0m0s))" query_hash=3075849878 start=2024-06-06T13:59:11.84Z end=2024-06-06T13:59:11.84Z start_delta=4.134870268s end_delta=4.134870751s length=0s retry_in=4.432957889s err="rpc error: code = Code(500) desc = failed to load chunk 'fake/1578df082a04901c/MThmZWQyYzQ2MTM6MThmZWQ5OTFkNmE6NzI3NzY5Y2E=': open //grafana-loki/chunks/fake/1578df082a04901c/MThmZWQyYzQ2MTM6MThmZWQ5OTFkNmE6NzI3NzY5Y2E=: no such file or directory"
logs from gateway:
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:30 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593679000000&query=max+by%28level%29+%28count_over_time%28%7Bapp%3D%22api-firewall%22%2C+pod%3D~%22.%2A%22%7D+%5B20s%5D%29%29&start=1717674780000000000&step=20000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:30 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593681000000&query=rate%28%7Blevel%3D%22error%22%2C+app%3D%22api-firewall%22%2C+msg%3D~%22Request+validation+error.%2A%22%7D+%5B30s%5D%29&start=1717674780000000000&step=30000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:30 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593680000000&query=max+by%28method%29+%28count_over_time%28%7Bpod%3D~%22.%2A%22%2C+app%3D%22api-firewall%22%2C+method%21%3D%22%22%7D+%5B30s%5D%29%29&start=1717674780000000000&step=30000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:31 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593681000000&query=sum+by%28msg%29+%28rate%28%7Bapp%3D%22api-firewall%22%2C+msg%21~%22%5E%28main%7Chandler%7CSending%7CReceived%29.%2A%22%7D+%5B1m%5D%29%29&start=1717674780000000000&step=60000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:31 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593665000000&query=sum%28count_over_time%28%7Bpod%3D~%22.%2A%22%2C+app%3D%22api-firewall%22%2C+msg%3D%22Error+while+proxying+request%22%7D+%5B2m%5D%29%29&start=1717642320000000000&step=120000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:47 +0000]  500 "GET /loki/api/v1/query?direction=backward&limit=1000&query=sum+by%28path%29+%28count_over_time%28%7Bapp%3D%22api-firewall%22%2C+pod%3D~%22.%2A%22%2C+msg%3D~%22Shadow+API%3A+undefined+parameters+found%22%7D+%5B21600s%5D%29%29&time=1717685593682000000 HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:48 +0000]  500 "GET /loki/api/v1/query_range?direction=backward&end=1717685593682000000&query=rate%28%7Bapp%3D%22api-firewall%22%2C+pod%3D~%22.%2A%22%2C+msg%3D%22Shadow+API%3A+undefined+parameters+found%22%7D+%5B10m%5D%29&start=1717674780000000000&step=30000ms HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
api-firewall-grafana-loki-gateway-5c7cbfc8b4-kwv2w 10.10.6.11 - - [06/Jun/2024:14:53:48 +0000]  500 "GET /loki/api/v1/query?direction=backward&limit=1000&query=sum+by%28path%29+%28count_over_time%28%7Bapp%3D%22api-firewall%22%2C+pod%3D~%22.%2A%22%2C+msg%3D~%22Request+validation+error.%2A%22%7D+%5B21600s%5D%29%29&time=1717685593681000000 HTTP/1.1" 218 "-" "Grafana/10.4.1" "-"
thanks in advance!
If you are deploying more than one instance of Loki you need to use a backend storage that is NOT filesystem.
