I’m using Grafana 8.1.2 and I currently run into the issue that I can’t see all the measurements when exploring the data. The dropdown to select the measurement shows only 100 entries whereas I have 149 in my InfluxDB. I haven’t set any filters. It just stops after the 100th entry.
Is there a limitiation / configuration to set how many measurements are listed in the dropdown?
Thank you in advance!
