Schema.measurements does not return all measurements in grafana
    Grafana v10.2.1 (533a733e4eda44041e43358c5a51203e9b42c9ea)
    Docker
    In a dashboard variable want to query the measurements in a bucket and filter them with a regex.
    In the variable of a dashobard I have entered
import "influxdata/influxdb/schema"
schema.measurements (
    bucket: "openhab"
and in the regex for that variable I entered
/^(?!.*Raw_Operation_State).*Operation_State/
  • What happened?
    Not all measurements in the openhab bucket are returned. There are about 2034 measurements in that bucket.
    That all measurements were returned and I could filter them all using a regex
    No errors in the Grafana UI. The log file shows no errors
    Explore your data schema with Flux | InfluxDB OSS v2 Documentation
Grafana has a limit of 1000 items for the variable, regardless of the data source.
See Variable: Return more than 1000 results · Issue #59959 · grafana/grafana · GitHub
