Hello! I have two variables, module_id and version_id. I want to extract version_id from a metric label with _module_id=$module_id. The problem is that I don’t want to enable “show on dashboard” for module_id, so when I do the mapping, I have nothing in preview. I can use =~ instead of =, but it doesn’t help: I want to display in dashboard panel version for each module. Maybe it is possible to set a propper repeat option in panel? But how?
Show variables in the dashboard first (for debugging/development). It is not clear which value has module_id variable (especially when you have enabled multi selection and All - I would disable those - it doesn’t make sense).
OK, so now prove that node_os_info has some value, where _module_id=PG-PRD-3.
