v. 9.0.8 -
Calculate vapor pressure deficit using Temp and Humidity readings fed to grafana via InfluxDB -
Server-side expressions - very beginner
Hi everyone, I’m VERY new to Influx/grafana. I have a small bank of sensors monitoring a grow tent. These sensors are feeding data to Influx and so on.
I am attempting to use temp/humidity readings to calculate other metrics similar to those in this post. Formulae for these measures are found here.
I’d like to know whether I can perform this kind of data manipulation server-side using InfluxDB? If not, is it possible with another database?
Thanks so much and apologies if this is an entirely ignorant question!
