grant2
1
The formula that I want to use to transform my data is (using Excel nomenclature)
=EXP((T-20.18768)/-30.5331)
Example: If T = 1625, then the value above would be 0.505791.
Is such a transformation possible using Grafana? I am sure I could use InfluxDB, but I do not want to store the value in the database.
grant2
3
Returns e to the power of number.
And I see Flux supports this:
Do you have any mysql or sql server in your env? Maybe you van use a function from those products? A fake select that uses such function?
Hello, i’m thinking you can maybe do an approximation of e^x by multiplication as polynome or something, since that you could perform it through basic calculation transformation in grafana i suppose.
I could help with this approximation maybe, how much this have to be exact value ?
http://www.nabla.hr/FU-DerivativeG2.htm#:~:text=The%20approximation%20of%20the%20exponential,Maclaurin’s%20formula%20or%20Maclaurin’s%20theorem
